04-23-2016 07:45 AM - edited 04-23-2016 07:48 AM
I know nothing about motor, motor control with PID, thus I would like to start to learn something (hand-on), so I purchased NI 9505 from eBay. Now I would like to purchase remain hardware to start but I am not really sure what brand/model I should purchase. So please help me by providing some recomedation on
(1) Motor (I do not need a lot of power, something 12VDC)
(2) Encoder
(3) Cable
As it is just personal learning, I would like to have something cheap/reeasonable. I will very much appericate.
04-25-2016 09:18 AM
The 9505 is a c-series I/O module - so that means you will need:
I am sure you can probably find something cheap for the things listed in the last point on ebay, just need to make sure it is compatible in terms of what the 9505 can drive (read the manual - http://www.ni.com/pdf/manuals/374211f.pdf). The first two bullet points may be a bit more difficult to get something cheap.
04-25-2016 01:03 PM - edited 04-25-2016 01:07 PM
I acctually have the cRIO 9024 and LabVIEW. All I need is the motor, encoder, and cable (Number 3). I would like to ask if someone can recommend some of the model/brand I should purchase - I am new and I do really want to purchase something that does not suite my need - which is just to learn new concept.
04-25-2016 05:24 PM
The manual gives the specs that the motor and encoder have to meet - here are a few points, but please read the manual yourself. I haven't used this particular IO module myself:
04-27-2016 04:04 PM
Thanks. I order Namiki Coreless Servo Gear Motor DC 12V 120RPM Gearmotor With Encoder for $10.50, hopefully, I can start to learn some motor control.
