02-02-2016 01:26 AM
Hi there,
does anyone created a application for the NI 5791 rf transceiver module with multi channel support? I've already used the example project, but I would like to change the channel (frequency) from the fpga side. That means I want to send a rf-message on two frequencies each after another, but within a specific timing. How can I realize that?
regards
Thomas
02-03-2016 04:58 AM - edited 02-03-2016 04:59 AM
Hi Thomas,
which Example do you use?
Chris
02-04-2016 12:20 AM
Hi Chris,
I used the "5791 Record and Playback to HDD" example (https://decibel.ni.com/content/docs/DOC-40250), but I removed the record and playback code.
Thomas
02-08-2016 08:15 AM
maybe it is possible to uplaod your VI? So i could better understand how you try this? 🙂
greatings
Chris
