Where are the Remote Panel Configuration Files located on the Linux RT Targets?
Also, if the SSL configuration of the remote panel configuration is located in a different configuration file, where are those located?
What I'm trying to do:
Enable Remote Panel Server
Set HTTP Port to non-default
Enable Remote Font Panels
Enable SSL
Setup non-default SSL Port
I need to do this programmatically, preferably by editing the configuration files on the target instead of using the LabVIEW project.
Thank you!
