05-09-2014 03:42 AM - edited 05-09-2014 03:43 AM
I am unable to compile FPGA-Projects. I am getting following error:
LabVIEW FPGA: The compile farm server does not have any compile workers that can perform this compilation.
Error -123002 occurred at niFpgaCompileFarm_OpenJob.vi Possible reason(s): NI-Farm: No worker has registered the given capability name. Complete call chain: niFpgaCompileFarm_OpenJob.vi niFpgaCompileWorker_OpenJob.vi niFpgaCompile_Worker.vi:6460001
My machine-setup:
Fresh-Labview install with all updates and Patches:
Labview 2013 SP1
FPGA Module 2013 SP1
Xilinx Tools 14.4
LVFPGAXilinx14_4f1Patch installed
.net Framework 4.5.1
My FPGA Compile Worker 2013 reports me twice:
Registered Capabilities: Xilinx 10.1 14.4 14.4 (64bit)
Does anybody know, what is going on and how to fix it? I am using brandnew cRIO 9068...... I really would like to use it!!
King regrads,
Yogi
05-09-2014 04:16 AM
Okay, I figured out the problem.....
My FPGA module was configured for compilation on remote server, which was not containing Xlinx 14.4.....
Setting to localhost in Options was the key.
Done.
Yogi
04-20-2015 09:22 AM
hi
i am also facing the same problem. where should i have to make changes?
waitingh for reply
thankyou..
04-24-2015 04:21 AM
i received the same error code. in my setup i was connected to a network compile server with the ip 127.0.0.1 (localhost).
after switching to "use local compile server" it worked.
you can find these setting under tools -> options -> fpga module in the vi-editing window. i am using a german version so i hope i made a correct tranlsation of the toolbar names
regards
martin
12-21-2020 05:05 AM
I am getting error while compiling. I have attched the images of error here. I have reinstalled the software completely but still I am not able to resolve it.
I have installed Labview 18 and compilation tool ISE 14.7 and Vivado 17.2 (Which are mentioned compatible on NI forum)
While compiling I am getting error as per attached image. I tried all the ways mentioned on https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019N2vSAE&l=en-IN and https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QmcSAE&l=en-IN
