08-11-2014 04:46 PM
Hello All,
Here is my problem in a nutshell:
When I try to open a SubVI that I have created, LabView runs out of memory and crashes. My system specs are below:
- LabView 2014 32 bit
- LabView Real-Time and FPGA Modules Installed (2014)
- NI RIO 14.0 Installed
- Windows 7 (64 bit)
- 32GB of RAM on my computer
I look at resource manager in Windows, and see that while LabView opens the VI, it uses up to 3.9GB of memory before crashing (since it is a 32 bit version of LabView, I am limited to ~4G of virtual memory). The same problem occurs when I try to: a) generate intermediate files, and b) Build the top level VI.
I suspect this problem is due to the fact that the top level VI has SubVIs that are kind of large (there are 5 SubVIs that are between 250 and 520 kilobytes each). The .lvproj file is 17.8MB in size, largely due to the fact that it uses a large number of memory items and registers. Unfortunately (for reasons I will elaborate on later if anybody is interested), I cannot reduce the number of register or memory items used in the project. But having said that, I cannot imagine why LabView needs more than 4GB of virtual memory to perform these operations (open/save the VI, generate intermediate files, etc). Any pointers would be greatle appreciated. Thanks!
Best,
Aditya
08-12-2014 03:09 PM
Hi Aditya,
Does this happen with other LabVIEW projects? Would it be possible for us to see a screenshot of the error you receive before LabVIEW crashes?
Jordan G.
08-12-2014 05:15 PM
Hello Jordan,
Thanks for your reply. No, this crash does not occur with smaller LV projects. The FPGA target is configured with a large number (1914) or U64 registers. This VI essentially has 33 cases in a case structure. Each case reads 58 unique register items and outputs a cluster of size 58. Obviously, 33x58 = 1914. I can explain the reasons for this weird implementation if you are interested. Before the crash, LV uses about 200MB if memory. At the time of the crash, it is ~4GB.
I've attached two screenshots:
a) before crash, and b) after_crash.
Please let me know if you need any other details. Thanks again.
Best,
Aditya
08-13-2014 07:02 PM
Hi Aditya,
Is this a fresh install or an upgrade of LabVIEW 2014?
Jordan G.
