NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Hitesh_Dhola
Is Current Limit resistor is necessary for NI 9606 inputs ?
Hey Friends,
I am designing a daugther board for 9606. I was confused when I seen maximum input current to DIO is 3 mA. What does it suppossed to mean ?
I have Signal of 3.3V to input in 9606, I have used buffer IC MC14011 to maintain level of input signal. Buffer is able to provide 300 mA current. I have maintained 55 ohm characteristic impedance for the daughterboard.
Now questions are,
1. Do i need to put current limiting resistor to the circuitory ? or It's input Impdeance is enought to handle ?
2. what is input impedance for any DIO in 9606 ?
3. Can 5V input given to DIOs or 3.3V is necessary ?
Hitesh Dhola
Member
ePower-ahp
Re: Is Current Limit resistor is necessary for NI 9606 inputs ?
Hi Hitesh Dhola!
Did you get answer to your questios, I am sitting in same situation...
Regards
Anders Pedersen
ePower Technology
Denmark
Active Participant
Wayne.C
Current limit of 3mA only applies when the DIO is configured to be a Digital Onput.  Since the FPGA tristates/floats DIO before and during configuration, you need to use pullup or pulldown resistors on pins so they are at a known level while the DIO is floating during initial powerup or during a reconfig.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
