01-16-2013 10:48 AM
Hi All.
I use Labview 2011 to control my thermal loop. So we have several thermocouples, pressure transducers, valves etc... For now, I don't have a problem with controlling and displaying the values but whenever I ask to get data, program slows down and I am not able to get data faster than 750ms. which I find is so slow. I should be able to get at least 200ms (which is not fast either but it is enough for us). I try to write measurements from several channel ( right now 53 channels) and I use write to measurement file express vi.
I made a small test program to see if my main program is so heavy or not. In this test program, I scanned 32 channel in NI9205 and tried to write the measurement with 100ms without displaying and I am still not able to write at that speed.
So, am I not able to configure correctly the scan engine of cRIO9074 or Write to measurement express vi is always slow ?
Thank you,
altan
01-17-2013 01:30 PM
Can you attach the test program so we can see how you have things set up?
01-18-2013 12:10 PM
Here is the test program with Write to Measurement File Express Vi.
Eventhough i ask 100ms, i am not able to write faster than 400ms with this set up. In my main code, i have 3 NI9205, NI9263 and NI9265 so I have many indicators. When i add all, code becomes heavy and i can't write faster than 750ms.
Instead of using Express Vi, i modified my main code using TDMS Open/Write/Close functions. With that i tried and able to write at 100ms which is enough for me. But i am not able to close the file so i can not change the file name and press save button so get another set of data. It adds(append) new data into the first file.
Thanks in advance.
altan
01-21-2013 01:39 PM
Altan,
Writing to a file is not deterministic. That is why you are not getting the performance you are expecting. It would be a good idea to queue the data you want to write to a file and dequeue and write it in a regular loop. Try to keep only deterministic functions in a Timed Loop and keep nondeterministic functions in regular loops. Hope this helps.
