11-23-2014 10:51 PM
I am using ni9478 DO card to give GATE pulse to inverter. I have made connection as per mentioned in datasheet, but I am not getting output. Please suggest me any solution.
11-24-2014 06:28 AM
The 9478 does really provide an output. It either connects the line to ground or doesn't. It does not output a voltage. Therefore, you must provide a pull up of some sort. What kind of pull up did you apply?
11-25-2014 03:22 AM
I want GATE pulse of 15 v for my inverter so I have given 15 volt supply to vsup pin
