06-30-2015 02:01 AM
I am testing an equipment and collecting some data using NI cRIO-9022. I run the program in scan engine model. However, When I try to plot the data, it told me that the command can not be used here. But I still want to watch the figure in Matlab. Do you have some good idea to solve this problem?
06-30-2015 06:00 PM
Hey,
It looks like you're using a MathScript node. It sounds like you want ot use a "MATLAB script node" instead, that should let you plot it.
06-30-2015 09:26 PM
Thanks, but it still doesn't work, because Matlab script node is not supported in the target. We have to think another solution.
07-01-2015 10:10 AM
You can't run Matlab on a cRIO. You would need to pass the data you're collecting back to a host computer, and use the "MATLAB script" node in a VI running there. You could also pass the raw data out and plot it on a waveform graph.
07-01-2015 10:27 AM
What would you even expect to happen with the "plot" command on a cRIO? A cRIO is a seperate computer with no GUI.
