How to set console font/resolution on CRIO9033
Hi all,
as we are using console to display some basic informations but the displays being used are very small (which makes text nearly unreadable), we need to set a bigger font or a lower resolution for console.
Found some common tutorials for common linux but didn't find the mentioned files to edit entries.
So our question: How can we set a bigger font or a lower resolution for console on a CRIO9033?
Thanks in advance, Jens
(2,481 Views)
Hi Jens,
the sizes on a RT Target with Embedded UI differ from the size you can see in Windows:
AE KB 6O07SO5A : Why Does My Deployed Embedded User Interface Not Look Like My Host User Interface?
http://ae.natinst.com/public.nsf/web/searchinternal/92a4978076b4969586257d27004c3529?OpenDocument
So normally I would propose that you should just select a bigger font size to your liking. Since that is something you probably already tried it could be that you encoutered that behaviour (concerns LabVIEW 2016):
AE KB 7C498I5A : Why are My Embedded UI Fonts the Wrong Size When Deployed From LabVIEW Real-Time 2016?
http://ae.natinst.com/public.nsf/web/searchinternal/99b1f5ce11a8087b86258006005134ab?OpenDocument
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(2,359 Views)
