05-22-2006 05:31 AM
05-23-2006 08:51 AM
To disable your current startup application on the 9002, you can just place the "No App" DIP switch to the ON position and reset the controller. You should then be able to download your new code to the unit without a problem. One thing to keep in mind when working with a cRIO system is that only one top-level FPGA VI can be on the system at any given time (since each bitfile configures the entire FPGA), but you can have multiple Real-Time VI's running.
05-07-2008 03:36 AM
Matt
I read your reply. but I don't follow your last part ("One thing to keep in mind when working with a cRIO system is that only one top-level FPGA VI can be on the system at any given time (since each bitfile configures the entire FPGA), but you can have multiple Real-Time VI's running"). could you explain more or give an example? thanks a million!
carl
05-07-2008 03:50 PM
05-08-2008 07:30 AM
05-08-2008 11:08 AM
08-03-2016 01:50 PM
How do I get the Ni Auth??
