How to create current-controlled interface?
I have a proportional solenoid valve, 24V coil, 800 mA at maximum stroke, which I wish to use current controlled, with compactRIO I/O modules.
What is the most cost effective combination of I/O modules that will allow me to do this?  As there is no analog current output module exceeding 20 mA, I presume that I need to implement PWM using a voltage output?  Would I measure the circuit current with an analog input module, and then pulse the voltage with a digital output module accordingly?
(2,921 Views)
CFER,
I agree with you, I believe you'll need a DO module and an AI module if you want feedback. Which modules you need will depend on your application. In fact this would be an excellent question for our sales engineers. You can reach them at (888) 280-7645. Exactly which modules you will need will depend on your application. Could you describe the application in more detail?
Austin
Staff Software Engineer
NI
(2,900 Views)
