05-06-2015 03:33 PM
Hello!
I am trying to figure out if it is possible to make a curl command on a cRIO?
like this:
curl - -upload ”myfile.txt” ”https://xxx.xxx/xxx"
05-07-2015 06:45 AM
Do i have to reverse engineer the curl command and make a Labview implementation af curl?
05-08-2015 02:47 AM
So i guess i have to find the curl.exe that will run on the compactRIO (NI Real-Time VxWorks-PPC603 6.3)
...but there is no package that will run on PPC603.
05-18-2015 10:47 AM
I would think this would probably be pretty painful on the VxWorks/PowerPC-based cRIO's. It would be straightforward on the Linux-based ones (903x, 906x), but on a VxWorks one, you'd probably need to track down some curl source code and build it as a VxWorks shared library and call it from LabVIEW...assuming you need to stick with your current cRIO, it would probably be easier to use a non-curl way to upload your file (FTP, WebDAV, etc.) that already has LV support.
