Having problem with CRIO9066
Hi guys,
I'm using Compact RIO9066 and NI C series module 9205 and 9264 to do the measurement in the project.
I've installed all the software required(Labview2015, Real-Time module 2015, FPGA module 2015 and
CRIO drive devices) and connect the RIO9066 to host computer with USB cable and put NI 9205 and 9264
into the slot of the RIO9066.
The problem is that I can find the CRIO9066 in the MAX but cannot find the NI 9205 and 9264, I don't know
what's going on there.
I would appreciate it if anyone could help me!
Regards!
Once for all!
(2,512 Views)
Hi Vidasll,
You have no problem there, everything is as expected. cRIO module do not show up in NI-MAX. I'm assuming you are use to DAQ where chassis and the modules would show up in the NI-MAX....
Here is a KB which addresses your question:
http://digital.ni.com/public.nsf/allkb/69A8C4DD97BDED3B8625735D005BDF19
(2,494 Views)
