Fuzzy Controller on cRIO FPGA
I am trying to implement a fuzzy controller on the cRIO 9073 in FPGA mode. My problem is that there is not even the a symbol of fuzzy controll to drag and drop. Are there any possibilities to do that?
I have already implemented the controller in scan mode. However, I want to implement it in FPGA mode to get higher performance.
Michael
(4,838 Views)
Hi Michael
You're right the fuzzy controller VIs are not shown under FPGA. The Fuzzy Controller VIs are implemented for
Windows or Real-Time. (They use DBL as data type which is not supported under FPGA)
It is possible to implement a Multi-Channel PID with the PID Express VI under your FPGA target. For more
information see at these two links.
PID and Fuzzy Logic Toolkit User Manual
http://www.ni.com/pdf/manuals/372192d.pdf
Using PID on FPGA Targets (PID and Fuzzy Logic Toolkit)
http://zone.ni.com/reference/en-XX/help/370401J-01/lvpidmain/pid_on_fpga/
Kind regards,
Andreas
(4,788 Views)
