Reply
Feedback on Getting Started with CompactRIO - Logging Data to Disk
Re: Feedback on Getting Started with CompactRIO - Logging Data to Disk
Hi waiki.wu,
Are you running the FPGA VI on the FPGA target or development computer?  You can check this by right-clicking the FPGA Target and looking under "Execute VI on".  If it is executing on the computer, it will not compile, which may explain the behavior you are seeing.  If you continue to see problems, feel free to post your code.
Elizabeth K.
National Instruments | Applications Engineer | www.ni.com/support
Message 21 of 98
(1,190 Views)
Highlighted
Hi i am not doing the FPGA target. I am using the RT scan mode on the cRIO, "CompactRIO Scan Mode Tutorial" in the web page. I just did another diagnosis on the VI. I put a probe at the connection before writing into the "Data buffer" variable, and i put a probe at the output of the "Data buffer" in the while loop. There is data writing into the data buffer, but there is no data coming out from the data buffer. The probe window said "Not executed". It seems like the "Data buffer" is empty.
Are these information helpful??
Message 22 of 98
(1,184 Views)
I think i got it. I forgot to wire the time out with the constant. and the red clock to the error in of the case structure. Thanks all.
Message 23 of 98
(1,181 Views)
I now have another issue. The tdms cannot be found in the c:\. and there is no errors in the error output. Can you help me with that?
Message 24 of 98
(1,174 Views)
Which c: are you looking at, the one on the host PC or the one on the crio internal RAM?
Message 25 of 98
(1,170 Views)
I was looking at the host pc. I didn't know there is a c: in the internal RAM.
Message 26 of 98
(1,167 Views)
FTP into the IP address of your CRIO, no username or password unless you set one. That caught me out at first too. You can use windows explorer for it but I'd use an alternative packages as MS implementation of FTP seems to be somewhat poor.
Message 27 of 98
(1,164 Views)
Thank you very much. I got it. I am a total newbie to this compactRIO and Labview. Thanks for the help. I really appreciate that.
Message 28 of 98
(1,160 Views)
Hi I am trying the FPGA mode this time. Everything works ok until i run it, I got an error after a few lines on the graph. The error code is "-61017", the text is "Open FPGA VI Reference in niLvFpga_Open_cRIO-9118.vi->RT.vi"
Does anyone has similar problem?? I tried to change the loop time and but still it doesn't help.
Message 29 of 98
(1,079 Views)
First, are you making sure to keep your FPGA VI closed while running your RT VI?  Also, it seems like you are able to get to the FIFO.Read portion of the code, which is after the Open FPGA VI Reference.  Do you have the Open FPGA VI Reference inside your while loop?  Could you post your code?
Elizabeth K.
Message 30 of 98
(1,066 Views)
