05-16-2013 08:40 PM
I'm expanding my RIO system with a 9146 Ethernet Expansion Chassis. I get the following error when trying to compile code for it:
Error -61499 occurred at niFpgaCompileWorker_AnalyzeTimingViolations.vi<-niFpgaCompileWorker_AnalyzeTimingPaths.vi<-niFpgaCompileWorker_CheckForErrors.vi<-niFpgaCompileWorker_JobComplete.vi<-niFpgaCompile_Worker.vi:1
Possible reason(s):
LabVIEW FPGA: An internal software error in the LabVIEW FPGA Module has occurred. Please contact National Instruments technical support at ni.com/support.
Additional Information: Traceback (most recent call last):
File "./objects/lvfpga_dist/win32U/i386/msvc90/release/root\resource\RVI\TimingViolation\scripts\niFpgaTimingViolationMain.py", line 280, in <module>
NameError: name 'constraintDict' is not defined
Return Code:1
Please advise if you know the cause of this issue and a solution.
Thank you.
05-17-2013 01:16 PM
05-22-2013 10:55 AM
I get exactly the same error when I compile a project with a 9237 and a 9514 module on a 9076 chassis with an empty FPGA vi. The same project compiles without errors when I remove the 9514 module from the project.
I am in contact with NI to try to resolve the problem, but they are able to compile the project without issues. I'm using LabVIEW 12, Xilinx 13.4.
05-22-2013 11:26 AM
It looks like you both have a timing violation. After attempting to compile, you should have the option to view the details of the violation in the compilation results window. This will open a window that explains the path that has been violated. Double click on it and it will highlight the affected path on your Block Diagram. If you are unable to view the details this violation, post your xilinxlog.txt file which is located at C:\NIFGPA\compilation\(folder corresponding to your compilation).
05-22-2013 12:14 PM
The error is internal and does not show a specific path or diagram component that causes a timing violation. The compiler ends iwth "An error occurred" not with "There is a timing violation" or something along those lines.
I tried a few things and I can compile with the 9514 by itself and the 9237 by itself. But when both modules are in the project I get the error.
I have attached to compiler log files.
08-15-2013 02:30 AM
08-15-2013 05:01 PM
Hi Umar,
Check out what I posted on this forum:
http://forums.ni.com/t5/LabVIEW/compile-error-61499-for-my-crio-9076/m-p/2523496#M766647
03-19-2015 11:25 AM
I encountered a similar error, but it's for devide sbbRIO 9642
The error information is in the following:
Error -61499 occurred at niFpgaXml_GetValue_String.vi<-niFpgaXml_SetValue_String.vi<-niFpgaBuild_Configure_AddToJobList.vi<-niFpgaCompileWorker_StartCompilation.vi<-niFpgaCompile_Worker.vi:1
Possible reason(s):
Additional Information: Missing required XML tag (/CompileServerList)
I tried the method you mentioned above, but it doesn't really work.
Any help?
03-20-2015 06:02 PM
03-22-2015 05:01 AM
Hi WenR,
I am trying to compile a FPGA IP node in the LabVioew and it reports such error.
I haven't tried the reinstall the software yet since I didn't see any post that is exactly the same problem with me. But will try.
THanks,
