Eclipse Include Files not Found
I have installed C & C++ Development Tools for NI Linux Real Time 2014, Eclipse, and am having issues with the "includes" folder populating correctly.
After installing the the eclipse software and creating a new project for C++ Hello World, I get unresolved includsion: iostream
After reviewing a colleagues computer with eclipse installed, the problem seems to be due to the CDT Cross GCC Built-in Compiler Settings not populating (ie. on my computer, this preprocessor include entry has nothing inside it, however on my colleagues machine, it has many includes and symbols defined).
I have tried uninstalling eclipse and re-installing, but still cannot find a solution.
Any help would be much appreciated.
Robert
(4,780 Views)
Could you post a screenshot of the CDT Cross GCC Built-In Compiler Settings window as it appears in your Eclipse environment?  And one of the error you are seeing?
Cody A.
(4,757 Views)
Hi Cody,
I have solved this problem.
I had a fortran GNU compiler installed on my computer (for use with some simulation software on my computer), and this seems to have caused all the problems.  When I looked at the paths included by the Cross GCC it was refering to the fortran directory rather than the National Instruments directory.  To solve the problem, I have uninstalled the fortran software and now everything works, macros and paths properly populated by the Cross GCC.
Maybe you have a better solution than to delete the fortran software?  Maybe modifying my $PATH environment variable so the NI path comes at the end rather than beginning?
Robert
(4,755 Views)
