10-27-2015 06:54 AM
hello
i am new to labview and myrio and here is my quistion
i am tring to find a way to read the nxt sensor in labview using the ( Digilent NXT Sensor Adapter for myRIO ) in myrio
http://sine.ni.com/nips/cds/view/p/lang/en/nid/212737
the problem is that the nxt sensors block and hitech sensoes they ask for port in nxt mindsorm brik wich i dont have one and i want to be able to read from this sensors using myrio and the adabter
and if there is any example code it will be more helpfull
can anyone help me with this
thanks
10-28-2015 04:05 PM
10-28-2015 05:12 PM
we are using labview for myrio platform and i dont thimk that the example you recomended will help me becouse they are using nxt mindsorm
and this is our main problem, how to adreess the nxt port to myrio
10-29-2015 07:53 AM
11-04-2015 08:18 AM
11-05-2015 02:37 PM
Hi emonzer
sorry for that. So when you connect the Digilent NXT Sensor Adapter for myRIO in the myRIO, then you connect the NXT sensors on it and you create a LabVIEW project and add the myRIO on it, are you able to see or detect the sensors? What do you see if you do that?
02-05-2016 07:50 PM
there are a couple of basic steps you need to take to read an NXT sensor into the NI myRIO via the Digilent NXT Sensor Adapter for NI myRIO.
I've tried this with the NXT LightSensor and NXT Ultrsound Distance Sensor and it worked OK.
I'll follow up if I get some more examples going. I am also looking into using the Digilent Motor Adapter for NI myRIO running with a NXT Motor.
I'll keep you posted.
cheers
Ingo
