Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
09-29-2015 05:53 AM
I have tried to compile my cRIO-9004 with local server.but it showed me the message that XILInk 10.1 not installed.
But i have installed all the required software in my ncRIO using NI max.
what is the possible reason for the problem?
Thank You
10-07-2015 04:14 PM
The software that the error is complaining about will run on your PC, not the cRIO. It's a separate install from the regular RIO/RT/FPGA installation. I think that this is what you're missing:
http://www.ni.com/download/labview-fpga-module-2014/4842/en/
It's 1.6 GB, so it won't be a quick download. Let us know if that fixes the problem.
Thanks!
We'll be in touch soon!
