05-20-2015 10:33 AM
I have a cRio 9030 with 2 USB host ports and one USB device port.
The device port is designed to be used as an ethernet connection to the host, but I am using the RJ45 port to do so.
As the USB device port is available, I'd like to disable the corresponding ethernet connection (usb0) in order to use this port as a classical USB port.
Is it possible to do so ? I guess this can be parametrized from SSH ?
Olivier
06-18-2015 06:39 AM
Hi oKermorgant,
As specified in the cRIO-9030 datahseet (cf page 3 http://www.ni.com/pdf/manuals/376260a.pdf):
The USB device port is intended only for use in device configuration, application deployment, debug, and maintenance.
What do you want to connect to this port ? (a USB mass storage)
Valentin
Certified LabVIEW Architect
Certified TestStand Architect
Certified LabWindowsCVI Developer
National Instruments France
