05-29-2012 02:45 PM
Hi Adlo
First, I delete the folder "PPC603gnu". Afterwards, i do the whole procedure (run "gccsetup.bat" and "make") which results in the same error message. Meanwhile, an empty folder (PPC603gnu) is created in the "example" folder.
Regards
Davarpanah
05-30-2012 03:36 PM
Hi Devarpanah,
thanks for the update, checking your %PATHS% environment variable, I see that you have installed Matlab Software which might point to a versioning problem for the compiler. Run the .bat file again and then type the following command in the command prompt:
c++ppc -v
which will produce the following output
Make sure that the gcc version matches the one I have above. Post your results and let me know of any differences, thanks!
05-30-2012 07:09 PM
Hi Adlo,
Thank you very much for your efforts
05-31-2012 07:25 PM
Hi Davarpanah,
could you send the the contents of your vxworks61gccdist folder? I would like to see if you have any partial PPC603 links when compiling. Thanks! (you can just everything in a .zip file)
06-01-2012 07:37 AM
Hi Aldo,
Because of the file size limitation, I divide the compressed file into seven parts. Please, after dowloading three parts, put them in a same folder, and extract the first part.
It should be noted that the attached zipped file consists of all contents of the vxworks61gccdist folder. Moreover, the mentioned folder is in the root C:\.
The first part is attached in this post.
Davarpanah
06-01-2012 07:40 AM
Second and third parts are attached
06-01-2012 07:42 AM
Forth and fifth parts are attached
06-01-2012 07:46 AM
Hi Aldo,
Two last parts are attached.
Let me know if you can extract the files. It is likely that you need the "Winrar" to extract them.
06-04-2012 04:38 PM
Thanks for the files Davarpanah,
I downloaded your code and ran it on a Windows XP 32-bit SP3 virtual machine without any problems. I was able to build the example program without any errors. The next step here would be to start fresh with your environment variables or to contact WindRiver (developer of vxworks) to see what might be causing the get_feature error in your message. I have attached a screenshot of the results.
It appears that other people are having trouble with the same issue with the c++ppc compiler:
2) http://forums.usfirst.org/showthread.php?t=18768
3) http://fixunix.com/vxworks/48355-ccppc-spawn-get_f
but no known solutions have been found. Keep us updated on what you find. Thanks!
06-04-2012 06:34 PM
Hi Adlo,
Thank you for your efforts,
Is there any other solution. For example is any commercial program available as a substitute for vxworks?
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
