09-16-2014 02:40 PM
You probably need to set the environmental varialble that basically says when I run make I mean run this thing over here in the lib directory. I believe I covered it after I installed MPI so you may need to do something similar. Search through the linux real-time group as this question has probably come up.
09-16-2014 09:19 PM
Kyle,
This time I only installed the "make". After being installed successfully,
I use echo "$PATH" to get my current path : /usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/usr/local/natinst/bin"
I use "which make" and the result shows: /usr/bin/make
Then I reboot the myRIO and login again, I got some problems.
1. I can only SSH login using safe mode. How can I get out of the safe mode? The first time I login in is "run mode", and the status LED on myRIO is totally off.
2. When I use "make", it shows that "command not found". It seems like make is not installed. I also cannot find "make" using "which make", but in the file system I do see make is still there. The make is already in the system PATH, so I think the environment variable should not be the problem...But why the program I installed do not work after myRIO reboot?
3. When I run "Get start wizard", it shows some error and prevent the accelerometer demo working.
Everything is abnormal after "make" is installed. Situation is the same for any other software I installed on myRIO. How can I solve these problems? Thank you!
Best,
Aoyu
09-17-2014 12:20 PM
Kyle,
The "make" problem has been solved after I upgrade my LabVIEW to 2014. Now I need the "GLib library" to be upgraded to 2.28. I have post this question to NI real-time community and hope to get a solution.
Thank you so much!
Best,
Aoyu
09-18-2014 07:58 AM
Aoyu,
The NI Real-Time community will likely be the best place to gather answers about this question. Many of our developers for NI Linux Real-Time monitor that forum to provide helpful insight. I think I saw your post over there yesterday with a few responses already!
