NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
R Gomez
Can't configure the NI PCI-6723 to be used with SIT in a RT Target
I am trying to implement a control system with multiple inputs/outputs in a Real-Time Target. The controller is built in simulink and therefore SIT (Simulation Interface Toolkit) is used.
For the inputs I am using the NI PCIe-6353 (32 AI, 4AO), which already works great for both input and output (I tried output just to check, but my application requires more than 4 outputs). However, I am failing to get a voltage out of the NI PCI-6723 (32 AO card).
I am not sure if the 6723 is not compatible to be used in this framework (SIT, RT target) or the mapping is not being properly done.
Any help is greatly appreciated!
Member
R Gomez
Re: Can't configure the NI PCI-6723 to be used with SIT in a RT Target
Ok guys... If I use the output card only it works fine... It seems that it has to do with RTSI.
I will check a little bit more about this and let you know if I can't make it work.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
