NI Home
Cart Cart | Help
You are here:
Reply
Member
moonm
CRIO
hi
i have labview 2010, and i'm beginner.
i want to start with examples "how to develop in CompactRIO"
i select Help >> Find Examples. Then i select Hardware Input and Output ..but i didn't find CompactRIO!!
Member
moonm
Re : CRIO
i will develop first then i will choose the appropriate CRIO
Member
Ryan_S
Re : CRIO
Hey moonm,
You've probably seen the reply to your post here by legolas, but I wanted to re-iterate that in order for the cRIO examples to show up in the example finder, and have the functionality I believe you're looking for, you'll need to install the LabVIEW Real-Time Module, LabVIEW FPGA Module, and NI-RIO driver. To ensure compatibility of your software, make sure you follow this table:
NI-RIO and LabVIEW Version Compatibility
http://digital.ni.com/public.nsf/allkb/577CC9A7DCFC73DF8625738400116CC3
Hope this helps!
--Ryan S.
Applications Engineer
Member
moonm
Re : Re : CRIO
Merci..
Now i have LV 2010
can u give me some link to download the LabVIEW Real-Time Module, LabVIEW FPGA Module, and NI-RIO driver
Member
Ryan_S
Re : Re : CRIO
Hey moonm,
You can find the 2010 versions of the LabVIEW Real-Time and FPGA Modules here:
Services Resource Center
http://digital.ni.com/src.nsf/display?ReadForm&lookup=LabVIEW&view=suproduct&node=node=203014_us
And NI-RIO here:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du/q/RIO/
Make sure you select the correct versions based on if you're using LabVIEW 2010 or LabVIEW 2010 SP1. Hope this helps!
--Ryan S.
Member
moonm
Re : Re : Re : CRIO
hey
thx for these links
so i should only install these three : the LabVIEW Real-Time Module, LabVIEW FPGA Module and NI-RIO driver ?
Member
Ryan_S
Re : Re : Re : CRIO
Hey moonm,
Depending on your specific application you may need additional toolkits or modules. However, for simply getting started with your cRIO and using the basic examples you should only need the Real-Time and FPGA Modules and the NI-RIO driver. For proper order of installation install LabVIEW, then the modules, then the RIO driver. Hope this helps!
--Ryan S.
Member
apeace
Re: Re : Re : Re : CRIO
[ Edited ]
any can help me to give a link to install the real time module for labview2011 and also link to install the crio driver..i just use the evaluation labview..i use a crio-9022..tq
Member
Ryan_S
Hey apeace,
For LabVIEW 2011, you'll need Real-Time 2011 and NI-RIO 4.0 which are linked below:
Real-Time 2011:
https://lumen.ni.com/nicif/us/evaltlktembdes/content.xhtml
NI-RIO 4.0:
http://joule.ni.com/nidu/cds/view/p/id/2598/lang/en
However, if you downloaded the evaluation version of LabVIEW then it's possible you're actually using LabVIEW 2011 SP1 in which case you'll need different links. So, double check your version and if it's LabVIEW 2011 SP1 then let me know. Otherwise, use the above links. Hope this helps!
--Ryan S.
Member
apeace
ok ..thank you.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
