NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
moonm
CRIO block diagram
HI
Can you give me the general block diagram of cRIO in serial communication (RS232)
and the detailed block diagram ( UART, FPGA)
best regards.
Member
BuddyHaun
Re: CRIO block diagram
If you are using the NI-987X serial modules in CRIO 901X, or greater check out the example in the NI Example finder under Hardware Input and Output>CompactRIO>Module Specific>Serial>NI-987x Serial Loopback.lvproj. If you are using Scan Engine the module can be addresses using regular VISA Serial communications as shown in the Hardware Input and Output>Serial>Basic Serial Write and Read.vi as long as you are running under RT. The VISA Serial communications apply to the built in serial ports on the CRIO systems.
Buddy Haun
CLA, Certified Trainer, Alliance Member, LabVIEW Champion
Member
moonm
hi
I mean block diagram without LabVIEW ( with visio for example)
Member
moonm
is it any links that can help me
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
