06-22-2010 05:59 PM
Hi everybody,
I am quite new to labview and appreciate your insights on the following questions:
I need to acquire analog data from NI 9205 and digital data from NI 9401, and then write them to a friendly file for further analysis in MATLAB and also recall them for my control program
After a little exploring here and getting some suggestions, I decided to use DMA FIFO. I've attached the screenshot of the FPGA file and the PC host file here.
1- Is this a correct way of reading and writing the file?
2- Is it correct to use the "write to measurement file" inside the timed loop?
3- I saw a post on this forum (see here )where the poster used a fancy method using consumer-producer structure. Is that necessary or I can get away without using queue functions? By the way, I need to recall these data in the main VI where I need them for controlling purpose. (Position control)
So, I do not know how to recall these data.
4- Are the chosen values for "Depth" and "Timeout(ms)" fine? 24000 and 0 respectively.
Overwhelmed Morris
P.S: I am using LabVIEW 8.6.
06-22-2010 06:11 PM
I am attaching the codes as well.
By the way, how should I decide about the number of elements(points) to read) and the FPGA period?
Morris
06-23-2010 11:18 AM
Hi Moris,
Check out the Logging Data to Disk tutorial in the Getting Started with CompactRIO series.
The FPGA section walks through creating a simple logging application from scratch.
04-11-2014 06:19 PM - edited 04-11-2014 06:22 PM
Hello 😃
So ima LabView noobie i got to this forum originally from the first one you started...
Hopefully im in the right place...
I went ahead and linked my design im working with and ultimately want to save and store data to:
1. an onboard memory device (there is a onboard SD im thinking would work)
2. being able to upload from the FPGA deice to a server (for testing purposes this server will be on the home network)
3. being able to access the FPGA saved files at any time from the server.
Like i said im a noobie and and been searching religiously for some direction...
Dont get me wrong im not looking for hand outs, just need to be pointed in the right direction... 😃
i followed the link you posted on how to "create a simple logging application from scratch" but noticing the date on this thread... i think it might be a little out of date =(
The RIO board im working with is a sbRIO9636 and while trying to follow the steps on the tutorial... there is a large unexplained gap between step 2 and step 3: Select the Appropriate Programming Model... they want me to use a Scan Interface but im not seeing the pop up window it is showing in the tutorial nor does it explain how to manually set it =((
Any and all insight is welcomed, for any knowage to me right now is a step forward in the right direction...
Also i do not mind elaborating on my circuit if needed... just didnt want to flood this thread with a bunch of nonsence if there is a better place to be asking =P
07-18-2014 05:31 PM
I am a new user to Labview and I have a question about acquiring data in FPGA mode. I have a compact CRIO 9024, 2 ni 9237 and one 9401 all configured according to the attachements. I tried a lot to take a reading using FPGA interface but I could not. I guess I do not program correctly. I just want to take very simple reading to make sure my sensor are working. As it is seen the indicator shows a zero value for every sensor I checked as if it is not working. I did not use any loop or something. This is a very simple thing. I would be grateful if somebody let me know how to write a very simple program to take my reading. I am sorry if my question looks very wierd to you in advance.
07-18-2014 06:24 PM
First of all, you should have started a new thread.
1) You need to use a loop so that you constantly read the line. Also be sure to put a wait in the loop to time how often you take the sample.
2) You are trying to interface with a cRIO. When dealing with the cRIO, your FPGA has to communicate with your RealTime OS. There should be a cRIO project template in there for you to play with.
