I'm having a couple problems with the 9012 cRIO with the 9205 breakout. I'm trying to measure voltages on the breakout and log them locally to a flash drive on the cRIO. I want to use a computer to start and stop the test, but I CANNOT have it be required to always be connected.
I've done a bit of research and found a couple VI's but no real hard code to do so. I just cannot figure out the computer connection problem.
Thanks.
