01-09-2014 07:09 PM
We are trying to format a crio and load an image using the FRC imaging tool 2013.9.25. The image version FRC_2014_v52.zip, It failed on the older 8 slot FRC cRIO as well as the newer 4 slot unit. The tool formats the crio and errors on the reboot. The error message is:
Error -2147220304 occurred at nisyscfg.lvlib:Restart.vi:1680001
Possible reason(s):
NI System Configuration: (Hex 0x800404B0) Timeout while waiting for reboot. System is offline.
Complete call chain:
ConfigUtility.lvlib:2012_FormatSystem.vi
ConfigUtility.lvlib:ReImageTarget.vi
ConfigUtility.lvlib:Dialog.vi
What do we do? FRC team 3010. Thanks!
01-10-2014 04:32 PM
This error message can come up for a variety of reasons, but is usually due to a network communication problem. Try the following troubleshooting steps to see if it makes a difference.
If none of these steps help, reply here and we will try to help you troubleshoot this further.
Shane C
07-30-2015 09:06 AM
Simply to document this for others - It is worth noting that this error can occur in the NI RAD Utility as well, and apply to PXI targets too I discovered this today. As it turns out similar solutions apply. For me it was the firewall this time around.
