RF Measurement Devices
waveform recording in NI RFSA phase coherent multi channel
Thanks for pointing that Mr. Andy. Sorry I've missed that parameter. Now I can convert my xml file to excel file. There are two columns in the excel file. I just want to confirm if the first column is for the I values, and the second column is for the Q values. I will attach the excel file in case you need to see it. Thank you so much for your patience in answering my questions. 🙂
Message 21 of 23
(2,843 Views)
Hi Margarette,
Your intuition is indeed correct, the first column is the I data and the second column is the Q data. I'm glad we could answer your questions and get you the results you were looking for.
Andy Hinde
RF Systems Engineer
Message 22 of 23
(2,841 Views)
hallo, i couldn't navigate to the added links .
Message 23 of 23
(68 Views)
