NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
margarette
Accepted Solution
waveform recording in NI RFSA phase coherent multi channel
Hi. I'm using the NI RFSA phase coherent multi channel example VI. How does the record option works? I can't quite figure out how to record waveforms properly and how to look at these recorded waveforms. Sorry, NI is still new to me. Thank you.
Member
Joe_S
Re: waveform recording in NI RFSA phase coherent multi channel
Hi margarette,
The example that you're working with allows you to record a signal that you acquire to a file and then use that file for playback generation. According to the block diagram, the Record button causes the VI to enter a Record state and streams acquired data to your disk in an XML file. This file should be saved at the location specified by the Recording Folder Base Path control. From there, you can open the generation project and use that file in Playback mode. But the data for the waveforms you acquired should be stored in those files. Does that help answer your questions?
Joe S.
Member
margarette
Hello! Thanks for replying. I've tried to specify an XML file at the Folder Base Path control but an error occurs. It says something like "LabVIEW General error". What could be the reason for this?Thank you
Member
KyleP
margarette,
You mentioned specifying a file, but the VI wants a folder. When the window prompt asks you to locate the file, use the Current Folder button in the bottom right to give LabVIEW the folder destination instead. Also, please always be as specific as possible with error messages so we have a better understanding of your issue.
KyleP
KyleP
Member
margarette
Hello Kyle. Thanks for your help! I was already able to record my waveform. Now my problem is generating the waveform in playback mode. Is it right to specify the RECORD METADATA (xml document)? 'Cause when I'm doing this an error says that XML value text is illegal or out of range for type and/or format. The screenshot of the error is attached. Thank you!
Member
KyleP
Does this happen with every record you try and generate, or only one specific file?
KyleP
Member
margarette
I tried it with two files that I recorded and the same thing happens.
Member
margarette
Hello! I have additional question. To regenerate the recorded waveform, where should I really specify the XML file? Is it in the 'Data File Path' or in the 'Record.xml File Path'? I attached the front panel picture. Thank you!
Member
Vimal_F
Looking at the block diagram it is going to be the latter, Record .xml File Path. Look at case 22 of the case structure.
Thank you,
Vimal Fernandez || Applications Engineer  || National Instruments || (512)683-1781 || Vimal.Fernandez@ni.com
Member
margarette
Thanks! I've already tried several times but the same error (the one I previously posted) still occurs. How can I solve this issue? I will upload the recorded xml file. I really need your help. Thank you.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
