NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
margarette
rfsg power level
Hello. I tried transmitting an RF signal at 6 dBm (peak power) but an error occurs. I attached the screenshot of the error. From my understanding, it doesn't allow power levels greater than 5 dBm. I have tried working at power levels less than 5 dBm and they worked just fine. But why is the power level limited at 5 dBm? Thank you.
Member
James_M.
Re: rfsg power level
Hello Margarette,
the message you're seeing is in fact a warning rather than an error (this you can tell by the status box having a check mark rather than an x). Warnings do not prevent the code from running; this particular warning indicates that you are trying to set the output power above the specified limits of the physical hardware, hence it's message:
'Requested attribute value exceeds device specification limits. Device performance is not guaranteed.'
So you can try running at the specified power level, but you may see clipping or distortion on your output.  If additional output power is needed, we recommend using an RF amplifier:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/207935
The above device would allow you to achieve up to 24 dBm of power.
All the best,
James M.  |  Applications Engineer  |  National Instruments
Member
James_M.
Hello Margarette,
All the best,
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
