04-09-2016 05:09 AM
hello
my company devloped a mesuremetn setup in which 4 rf power meters are used .
when this testing setup runs 24*7, it occures that randomly usbs arent detected in pc.
and retires of plug again it strats to be shown on ni soft front panel.
i have reinstalled usb drivers.(usb2.0 and3.0)
i have reinsttalled drivers of rf power meters
changed pcs.
but the issue remain random occouing
dont know what to do with it?
04-09-2016 05:10 AM
issue is something that ...
device manager of pc detects the connected rf powermeters.
but ni soft front panel not shows the device
04-09-2016 11:46 AM - edited 04-09-2016 11:57 AM
This is the feedback forum about the forum itself. You have a technical question which does not belong here.
I cannot figure out where your posts belong, because you don't provide much information (e.g. OS version). Please have a look here and then tell a moderator where this thread should be moved. (In the upper right of the posts, go to options...report to a moderator).
(EDIT: Apparently, the thread got moved to a more appropriate place)
(If this is Windows 8 or higher, see if fast startup is enabled)
04-10-2016 12:09 AM
04-10-2016 10:46 PM
04-10-2016 10:58 PM
04-10-2016 11:55 PM
the issue is something that measuremt and automation explorer is detecting rfpowermeters but it is not shown at ni soft front panel.
refer attachement.
i have downloaded version 1.2.0.0 and tried
but the issue remains.
04-11-2016 11:11 AM
Please try version 15.0. This release includes improvements both to MAX and the NI Soft Front Panel. Also note that the SFP locks the session to the power meter as does the driver API. This means that you can only be using the driver OR the SFP OR MAX (not two of those at the same time) as they all communicate with the device.
Do the power meters become undetected while you're running the SFP or while you're using the driver?
04-12-2016 02:24 AM
I AHVE TRIED VERSION 15.00 NOW,
THERE IS NO IMPORVMENT.
AT FIRST NOTHING IS DETECTED, NI MAX IS DETECTED ALL FOUR OF RF POWERMETERES BUT FAILED IN SELF TEST.
WHEN I TRIED CONNECTING ON NEW PORTS, I GOT ONLY TWO OF THEM ARE DETECTED,
AFTER RESTARTING AGAIN AND AGAIN , I GOT THREE DETECTIONS OF RFPOWERMETER,
the fourth is coming in device manager, NI max but it failed in self test of it.
the issue is in driver ......
not happy as detaction is changing after each restart.
i have to plug n play each time for the detaction but one of the powermeter is not shown in SOFT FRONT PANEL.
04-18-2016 12:41 AM
