NI Home
Cart Cart | Help
You are here:
Reply
Member
Ghooi
ni 5680 frequency range selection
Is it Possible to configure the range of freqency to be measured for Ni 5680 RF power meter?
Specifying the lower and upper value for the channel?
Member
mbb25
Re: ni 5680 frequency range selection
[ Edited ]
No.  The 5680 measures all frequencies present on the input signal.  The way power meters are built, there just isn't a way to distinguish between frequencies.  You could use a spec an to do this.
For example, there isn't a way to have the power meter measure the power level of a signal at 1 GHz without including the power from a (large) signal at 2 GHz.  Note that smaller signals probably won't matter to you.  If the signal you want to ignore is at least 20 dB lower than the signal you are interested in, then the measurement should be off by less than 0.05 dB.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
