11-25-2008 08:59 AM
I am running the standard example ni5640R Analog Input and Output in LabVIEW 8.2.. It sends QAM/Single tone to the NI board and through the direct connection between Tx and Rx, I made, it receives data. It was running fine but after some time, whenever I hit the stop button, it gave me the error:
Error -61046 occurred at NI5640R 8.2 (SubVI).vi
Possible reason(s):
LabVIEW FPGA: An error was detected in the communication between the host computer and the FPGA target.
If you are using any external clocks, make sure they are connected and within the supported specifications. Also, verify that the rate of any external clocks match the specified clock rates. If you are generating your clocks internally, please contact National Instruments Technical Support.
I did highlighted execution and found that execution is without error before it enters "Close FPGA VI reference". When it comes out of it to enter the "Simple Error Handler, it gives an error.
Please tell me what should I do. It is indeed urgent as I have a time bound project going on.
Thank you,
Rohit.
11-26-2008 08:27 AM - edited 11-26-2008 08:28 AM
Hi Rohit,
The 5640r is only supported in the IF-RIO forum. It looks like someone else has already seen this problem and a
solution was post. After you try the solution, feel free to post your results on the correct forum, we want to know if
the solution worked for you.
11-27-2008 08:58 PM
Apparently the problem got sorted out !!! I was restarting the computer but it was of no help. I had to get some updates installed so I shut it down and then started again. And the VI
started working.
I don't know the reason but I believe that during restart, the NI board might not shut down or get resetted and some interrupts are still being triggered whereas when I shut down, it resets itself completely.
Thank you anyways for the help.
-Rohit
