Hi Nathan,
The VIs from that article do fully convert the IQ data from unscaled I16 values to properly scaled decimal values, using the RFSG Playback Level property (along with some other math & functions). This can be seen within the block diagram of the main VI (Read PC Binary Data File and Write to Excel.vi). You should not need to do any additional conversion.
Hope that clears things up!
Cheers,
James M. | Applications Engineer | National Instruments
