12-04-2014 09:00 AM
hi, I am new to Labview. I want to implement (simulation of) receivers that are homodyne and heterodyne receiver in labview and want to get the SNR and BER plot. can i do that in Labview.
Following elements are involed in those recievers: Low noise amplifier (LNA), mixers, bandpass filter, Lowpass filter, Analog to digital convertor i.e sampling and quantization
Solved! Go to Solution.
12-05-2014 03:03 PM
There is no built-in functionality in LabVIEW that would directly allow you to simulate these components. However, if you know the math behind them, you could write the code yourself to simulate these parts.
You may also want to look into the Modulation Toolkit for some of the signal processing you mentioned:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210568
12-06-2014 12:53 AM
Ok. Thank you
