RF Measurement Devices
Power Spectrum VI gives different peak amp. vs RFSA front panel?!?
Hi Brandon,
Are you saying that the dBm returned after calculation is 10 higher than the value returned by the Power Spectrum and PSD VI or 10 higher than the RFSA SFP reading? If it is only coming out 10 higher than the regular dB reading then that is in line with what we have been thinking so far, and should match exactly to the RFSA SFP as the original poster wanted. If you are seeing an even higher power level than the RFSA SFP then I am not sure though, I haven't had a chance to run through the steps you laid out on our end.
Peter Williams
Message 11 of 12
(3,054 Views)
I think I'm straight now.  Cross-linking to this post.  Thanks for the discussion!
Brandon
Message 12 of 12
(3,037 Views)
