RF Measurement Devices
NI Recorder System
Any available solution for recording signals with 500MHz bandwidth with expected power signals around -150 dBm?
Operating frequency is around 4GHz.
What available hardware modules can be use?
(4,159 Views)
The only RF instrument we have with a bandwidth of 500MHz or greater is the PXIe-5668R:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/212699
The signal power may be a problem however, as the noise floor at 4GHz is specified to be -161dBm/Hz.  So for a bandwidth of 500MHz, you would see a noise floor of -162dBm +87dB, or approx -75dBm.  You would need to amplify the signal.
Jon F.
Applications Engineer
Jon F.
Technical Support Engineer
(4,142 Views)
