RF Measurement Devices
NI-RFSG 5671 low level output problem
A problem in NI RFSG.. The problem is when the output level from RFSG is low, there’s some much noise. There's a method recommended by NI that the problem could be somewhat corrected by using a 30dB attenuator just ahead of the dummy antenna and increasing signal strength by 30dB from the RFSG to compensate. . However, according to my observation, there's still significant noise.
 I don't know whether somebody have the same problem with me and hope  NI could investigate this issue ASAP.
Thanks!
Jacky
(7,276 Views)
Hello Jacky,
I'm currently trying to answer all previously unanswered posts on this forum category.
So please let me know if I can still do anything to help you.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,826 Views)
I just ran over this "discussion" when I was looking for informations about low level output problems. I hope I get help faster than my predecessorSmiley Sad 2006 --> 2012
I am sending a FSK modulated signal with my NI-RFSG (PXI-5671) equipment and I found out that my other Signal Generator (Rohde&Schwarz SMIQ 03B) is better in lower levels.
How did I find out?
  • I am measuring sensitivity on a RF-transceiver in a certain debug mode
    • I am sending the signal 10times. As long as 9 from 10 frames are counted on transceiver, I am decreasing power by 1dB
  • The NI-RFSG will stop at -99dBm sending power
  • The R&S SMIQ will stop at -104dBm sending power
  • The signals are identical, only the upconversion differs
Could it be that on very low power levels all the noise is amplyfied also? What can I do to increase the Noise to Signal gap?
Any suggestions would be highly appreciated...
Thanks in advance, Michael
(5,374 Views)
Hello Michael,
Can you repost this question as a new post and post the link in this thread?
I think this might be the easiest way to get more replies
I will then also continue posting in that new thread.
PS: In my effort to clean up this list of forum posts I did alot of "outdated replies".
Kind Regards,
(5,365 Views)
