11-28-2016 11:33 AM
Hey, hope someone can help me...
i tryed to use a VI from NI:
http://www.ni.com/example/52073/de/
but i got numerous error message after labview tried to open it:
Poly-VI 'MSO Configure Analog Edge Trigger.vi': SubVI is missing.
And a lot of more from this type e.g.: MSO Run.vi
The problem is i cant find those MSO subvi´s via google or here.
Or are they not downloadable for free?
Thanks a lot!
Solved! Go to Solution.
11-28-2016 01:04 PM
You need to install NI-Virtualbench. Here's a link to the latest version. http://www.ni.com/download/virtualbench-driver-16.0/6345/en/
11-30-2016 06:28 AM
thanks john, now i can open it... but dont use it because i dont have the required hardware. i thought i can use it with my NI scb68a.
can you tell my how i can "freeze" or pause continously measured real time signals from produced with a Mems sensor?
i tried to create my own oszi and i have the idea to do it with a trigger, but always when pushing the trigger, my signal gets lost!?!?!? o.O
11-30-2016 01:29 PM
Sorry. I'm afraid I was just answering the easy question regarding the broken VI. I won't be of much use to you. You might try posting your question in the VirtualBench forum. http://forums.ni.com/t5/VirtualBench/bd-p/340
