04-03-2017 09:46 PM
I would like to create a non-square configuration list for an RFSG (VST). The NI example "RF Configuration List Power and Frequency.vi" (or some such) makes a square list (same number of power and freq steps that change at the same time). I want to step in freq, do a bunch of powers, step in freq,... Tried wrapping the create config list step in two for loops, NI AE told me LV can't do that(?). Any smart guy have a better idea, please?
04-06-2017 09:32 AM
Sure, you can do that. Sounds like there was some misunderstanding with the AE.
Have you tried this (see attached):
04-06-2017 10:35 AM
04-06-2017 12:38 PM
Hey ThreedB, what version of LabVIEW are you using? Does the attached VI work correctly for you?
I ran this on LV 2015, non-SP1, no patches.
04-07-2017 10:38 AM
The attached VI works fine for me (same as what I posted before). I'm using:
NI PXIe-5646R
LabVIEW 2015, 32-bit
LabVIEW certainly supports doubly-nested for loops. This is really basic, and one of the core things I use LabVIEW for regularly (across many LabVIEW versions). Glad you were able to work around the problem, but I don't want you to feel like you have to avoid doubly-nested loops in LabVIEW. There's probably some other detail about this that is getting lost in translation. Does the attached VI work on your system?
