07-24-2014 01:12 PM
I am trying to test a GPS receiver and would like to use the PXI-5671 to stream a GPS binary data file which was generated using the GPS toolkit. I tried using the RFSG Arbitrary Waveform Generation.vi but it doesn't work. Is there a sample code that will allow me to do this?
Thank you.
07-24-2014 10:29 PM
You can use " niGPS Streaming From File (5671).vi" to do the streaming of your generated file.
You can find it on the GPS Toolkit examples.
James
07-25-2014 03:30 PM
Thanks James. Is it also possible to stream the GPS binary file from the PXI-5671 without using the GPS toolkit? The reason why I am asking is that I am presently trying out the evaluation version for the toolkit but going forward we may not have the budget to purchase it so I was wondering if the RFSG can stream the data by means of another method?
07-28-2014 03:36 PM
The NI-RFSG driver certainly allows you to stream waveform files to signal generators without the use of the GPS Toolkit, as shown here. However, the NI-RFSG driver does not provide the user with out-of-box applications that can stream GPS waveforms with Almanac and Ephemeris information to various signal generators. For this reason, the NI GPS toolkit will be needed.
The only alternative is that you will gather your own Almanac and Ephemeris files and implement your own functionality using the base RFSG driver to generate and stream the GPS signals. This is something that you would need to do on your own, which could prove to be difficult, thus making the GPS toolkit the best option.
I hope this information helps.
Regards
