05-19-2008 12:25 AM
05-19-2008 02:15 PM
Hi Sree,
I would like to ask for any VI’s you are using, along with further information about your project. I believe you are using the 5640R (IF-RIO), correct? From the post, I believe the 5640R is being used for PSK acquisition, but what is being used to generate your signal? I would like to ask for as much detail as possible ( all rates, inputs, outputs, etc) when you post, so we can best help to determine why you are not seeing the correct signal.
05-20-2008 01:52 AM
05-20-2008 03:48 PM
Hi Sree,
I do not know the formulas or methods used to create your images psk1.jpg or psk2.jpg, along with not knowing the bit pattern for your BPSK signal, so I cannot say if they are exactly correct, but the FFT looks reasonable. With the limited information from the post, I cannot determine if the LabVIEW VI is giving correct results, therefore I would like to again request information from my previous post – Can you please post the VI used for 5640R Acquisition? What is generating the signal (5640R or 3rd party device)? What is the bit pattern being used for the BPSK signal? It is good to know that you have Fc = 8.6M, and Fs=25M, but what is your IQ rate? With BPSK, we should not see amplitude changes, but only phase changes, so the LabVIEW image demonstrating only phase changes does not seem incorrect.
03-20-2012 04:54 AM
hello, David L.,
I am also trying to use 5640R to get a PSK modulation signal. But the result is not correct. The envelope should be constant in PSK modulation signal. what I get is shown in pic1.
My Host and FPGA .Vi is posted in pic 2 and pic3.
can you help me to resolve it?
Niton
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
