08-26-2010 04:41 AM
I have an NI- 5641R IF receiver and i am using Labview 2009 SP1.
I need to receive FM radio channels by using the above.
Please help me how to do or send me any examples related to this....
08-26-2010 02:54 PM
Have you looked in the example finder in LabVIEW? Do you have a downconverter to go with your 5641? If you do see here
Hope this helps.
08-27-2010 03:38 AM
Thanks GovBob.....
Now i am not having any downconverter. I am having NI PXIe-5641r only.
With this is it possible to do FM demodulation......
08-27-2010 08:11 PM
I don't have that particular card. You would need the carrier frequency to be within the specifications of the 5641 in order to demodulate the signal.
11-26-2010 09:14 AM
in RF communication library is a FM demodulator included: -> http://decibel.ni.com/content/docs/DOC-4068
Works with me - but without downconverter you would not fall in usual range of terrestrial FM radio stations (87 - 108 MHz). IFRIO just goes upto 80 MHZ as far as I remember.
Greets,
Lars
11-28-2010 11:15 PM
Thanks for your reply Lars.B. I am trying to use the FM demodulation in RF communication library but i am getting the demodulated output as zero.
I am attaching my code below.
Please have a look.
11-29-2010 02:35 AM - edited 11-29-2010 02:41 AM
In your FPGA code "input valid" is a constant value and "ready for output" not used.
"Input valid" should be wired to the feeding FIFO (in the way NOT[timed out?]) and "ready for output" linked to the output of your code - in this case "stream fifo 16".
"Ready for input" should control data source (here reading the FIFO "local") - only not necessary when your timing of the feeding source is always slower than the processing part (e.g. when atan is set to 1 sample per tick).
Actual the data flow is uncontrolled, so that the demodulator is not processing the correct (valid) data.
Also, I don't think that there will be 65500 elements in one second timeout... try a lower value (like 2000).
Maybe take a look in the example in the library, there it is how it works..,
Greets,
Lars
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
