NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
M. A. Rimpelainen
FSK modulation with symbol rate 9600 causes error.
I'm tryng to generate 2GFSK (2 symbols, gaussian filter ) with PXI-5670 RFSG. Modulation supposed to be  done with 3.4kHz deviation and 9.6 kHz symbol rate.
With these parameter I  get out of waveform memory error from ni-RFSG Initiate.vi.
Parameters are:
Symbol rate: 9600
FSK Deviation: 3400
PN Sequence order: 9
Samples per symbol:16
Filter parameter: 0.5
Filter Characteristic: Gaussian
Filter length: 8
If I change symbol rate to 24kHz or higher, signal generation works fine. Size of array Y in complex waveform is equal in both cases.
How can I get reduce actual ARB-memory usage?
Active Participant
ThiCop
Re: FSK modulation with symbol rate 9600 causes error.
Hello M. A. Rimpelai,
I see that this question has remained unanswered for quite some time.
Is this issue still open?
Kind Regards,
Thierry C - Platinum Applications Engineer - NI Belgium
CLD
If someone helped you, let them know. Mark as solved and/or give a kudo. :smileywink:
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
