I'm tryng to generate 2GFSK (2 symbols, gaussian filter ) with PXI-5670 RFSG. Modulation supposed to be done with 3.4kHz deviation and 9.6 kHz symbol rate.
With these parameter I get out of waveform memory error from ni-RFSG Initiate.vi.
Parameters are:
Symbol rate: 9600
FSK Deviation: 3400
PN Sequence order: 9
Samples per symbol:16
Filter parameter: 0.5
Filter Characteristic: Gaussian
Filter length: 8
If I change symbol rate to 24kHz or higher, signal generation works fine. Size of array Y in complex waveform is equal in both cases.
How can I get reduce actual ARB-memory usage?
