RF Measurement Devices
Error -239020 occurred
I am using RFSA 5661 (5600+5142). When I run my test VI, the error show up:
Error -239020 occurred:
Internal Hardware Error occurred in MIG hardware. Please contact National Instruments Support.
Component Name: nimxslu proxy
File Name: This is NOT an error in nimxslu. See nimxsl/tStatus2KernelProxyWrapper.cpp for information
Line Number: 290
Status Code: -239020
The following error is from test panel in MAX:
Error -1074118655 occurred at niRFSA Initialize.vi
Possible reason(s):
The digitizer returned the following error:
Line Number: 290
Thanks for any helps.
(5,387 Views)
Hello cxl6288,
MIG errors are typically bad news.
It sounds like the digitizer (5142) is acting up.  From MAX, run a self-test on the digitizer itself, and see if you can use it with the NI-SCOPE Soft Front Panel.
I suspect you will get a similar error message - and if you do, the card probably needs to be sent in for RMA.
Instructions for beginning the RMA process may be found here.
Good luck.
Matthew H.
(5,372 Views)
Thank you for reply. Yes, I got same error from scope test panel in MAX. Thabks again for help
(5,350 Views)
