09-16-2014 05:12 PM
I am using RFSA 5661 (5600+5142). When I run my test VI, the error show up:
Error -239020 occurred:
Internal Hardware Error occurred in MIG hardware. Please contact National Instruments Support.
Component Name: nimxslu proxy
File Name: This is NOT an error in nimxslu. See nimxsl/tStatus2KernelProxyWrapper.cpp for information
Line Number: 290
Status Code: -239020
The following error is from test panel in MAX:
Error -1074118655 occurred at niRFSA Initialize.vi
Possible reason(s):
The digitizer returned the following error:
Line Number: 290
Thanks for any helps.
09-17-2014 04:40 PM
Hello cxl6288,
MIG errors are typically bad news.
It sounds like the digitizer (5142) is acting up. From MAX, run a self-test on the digitizer itself, and see if you can use it with the NI-SCOPE Soft Front Panel.
I suspect you will get a similar error message - and if you do, the card probably needs to be sent in for RMA.
Instructions for beginning the RMA process may be found here.
Good luck.
09-19-2014 02:06 PM
Thank you for reply. Yes, I got same error from scope test panel in MAX. Thabks again for help
