02-10-2015 05:03 AM
02-11-2015 06:57 AM
Hi, When i tries to acquire GSM IQ data with filter active i.e else if (RBWFilterType == MODT_GAUSSIAN_FILTER) {; the code hangs at checkWarn (
niRFSA_FetchIQMultiRecordComplexF64 (rfsaSession,"",0, NUMBER_OF_RECORDS,numSamples,-1,waveform,wfmInfo));
while if i comment the filter i get the following error image attached.
What could be the problem?
02-12-2015 04:55 AM
02-18-2015 02:19 PM
Hi waciuri,
I took a look at this with my colleague who responded to your other thread here: http://forums.ni.com/t5/RF-Measurement-Devices/GSM-IQ-data-capture/td-p/3082271/page/2. Currently we'd like to make sure that you are able to detect your GSM signal correctly in the soft front panel, as this error looks like the same issue in that the signal is not detected. If we can trigger and see the signal correctly properly in the soft front panel, that should also resolve the errors you're seeing here in the CVI GSM analysis examples.
